Amp turn off pop
  • 1
Revelle
CarAudio.com Newbie
13
7
Texas
So I've got some pop when my amps turn off, I've done some googling but still unsure what my fix may be.
So I'm getting signal from my factory stereo that goes into my LC7i, from there I've got RCA's into my Dayton DSP, then RCA from there to amps.
If I unplug RCA from amp I get no turn off pop.
If I leave RCA from DSP to amp but unplug RCA from DSP to LC7i, I get no pop. So it seems to be coming from the LC7i somehow.
Any ideas on how I can fix this issue? I've seen people mention ground isolators, would something like an RCA ground isolator between the LC7i and DSP do any good? Or is some sort of delay what I need.
Well, I found a way to "fix" the popping. Ran a separate remote turn on from an acc fuse to turn on only the amps. Still using the LC7i GTO to turn on the LC7i and the DSP.
So now the amps only turn on once a turn on ignition. Where before they would turn on when the car unlocked/door was opened with the LC7i.
So some type of time delay may have fixed the original way I had it but, this will work just as good.
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
792
YES.The Remote wire turns the amplifier On/and OFF. If you use a Toggle switch as stated, use one that Lights up so you know if its still ON or...
5
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
122
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
198
Revelle
CarAudio.com Newbie
Revelle
Texas
Revelle
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
