Amp Upgrade Help Please
  • 1
I have been lurking here for a while and have already learned a lot from you guys. I am about to try an install that is a little more complicated than anything else I have tried before and need som advice. I am trying to swap out the factory amp (not a Bose system) in my 2009 Cayman and need some help trying to figure out the new set-up. Current factory system has 9 speakers running on 7 channels (2-4" rear, 2-4" door, 2-7.75" mid bass woofers in door, 2 tweeters in dash, and 1 center in dash). Each speaker has its own direct wire to the amp and the tweeters have resistors on them. The door 4" and tweeter run on one channel. I also already installed a powered sub behind the seat which gives me all the bass I really want.
The factory speakers are pretty good but the amp is way underpowered. I do not plan to run the center speaker so I want to see what the best way is to run the other eight. I have looked at running a 5 channel amp (2 rears on 2 channels, 4" doors and tweets on 2 channels, and door midwoofers on one channel), but am pretty shocked at the price of a 5 channel amp that will allow me full adjustability on the 5th channel for the midwoofers (I think I need HP control and not LP on this channel).
I think my other option is running a 4 channel amp with a passive crossover (run the 4 door speakers and 2 dash tweeters on 2 channels and the 2 rears on the other 2 channels). I would install the crossovers near the amp. From what I can tell, this would be far more friendly on my pocket book since 4 channel amps are much less expensive and I would have more adjustability woith the crossovers.
Now, what am I missing and what is completely wrong with my ideas? Also, any recommendation on amps/crossovers? Im really a middle of the road guy and don't have to have the greatest and best. Thank you for the help; I obviously need it.
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
158
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
352
6
470
annapolis76eb
annapolis76eb
Annapolis, MD
annapolis76eb
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
