Amp wiring help
  • 3
If you wanna bridge that amp on a single d2 sub, you have to wire it at 4 ohms. I dont think that amp can handle anything below 4 ohms bridged. So wire the sub in series. Take the + from one voice coil and run a wire to the - on the other coil and the last two, just run them to the box terminal.
That amp appears to be stable @1 ohm bridged.
If you only have one D2 sub just wire it in parallel to get a 1 ohm nominal load. + to + and - to -
That amp is class ab and should pull crazy amounts of current bridged @ 1 ohm if it does rated. Any electrical upgrades? what sub?
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
11
well ****, thanks anyways. Will leave the thread open just in case someone knows anything :)
caw1989
caw1989
Rochester, NY
Crapalier
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
