Amp wiring question...please help
  • 1
Fightingeagle12
I am planning on upgrading my system with a 2000rms amp. I currently have single run of 4 gauge wire that is about 12 feet. Could I get enough power with another run of 4 gauge or should I pull it out and run 1/0 gauge wire? It’s a spl car if that makes a difference.
Also, does anyone know the difference between wire found at a local hardware store (aka Home depot) and far more expensive installation kits? It sells for $2 a foot as opposed to $9+ from crutchfield.com. It would save a lot of money to use that instead.
577
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
I have a jeep wrangler 2010 4 door.. So 2 of my speakers are in the dash upfront. And the other 2 are in the bar in the middle of the car
For clarity, why not example 2 ? Example 2 is 2 ohm...my speakers are 4 ohm and amp uses less RMS wattage with the bridged 4 ohm full range...
Fightingeagle12
Fightingeagle12
Manchester, NH
Fightingeagle12
