Ampere Dsp Software help
  • 1
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
615
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
537
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Chris McNeeley
Red Light Ear Rapist
Chris McNeeley
Toledo, ohio
Chris McNeeley
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
