amplifier issues
  • 4
finnmorgan
I have bought a car with a very professionally installed Kenwood system from the early 2000s I assume.
The issue i'm facing is in the Kenwood KAC-8404 Amplifier. For some reason the A-channel only output on the right speaker. The mono switch forces audio to the left channel and so there is no output from speakers. The same symptoms occur when I tried swapping the speaker wires across left/right and trying the other speaker pair. And each of the four RCA input cables are working. I'm not sure if this is a failure in the amplifier or wiring. Maybe there is a procedure in wiring it I'm missing? 47411FCB-8BDB-4954-ABC6-81FF99575D2C.jpeg
I would pull it out and bench test it. Some Audio shops will Bench test an amplifier fairly cheap or will charge nothing at all to a good returning customer
Would you take a better picture of the buttons? When you set a switch to mono I assume you have to bridge the left and right channels.
46567
46568
could the switch be broken from old age? Maybe Ill test that with a multimeter, I was able to take it apart earlier for an inspection and didn't see anything glaringly wrong.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
The CT's are nice, That Sundown is a a frik'n beast!
748
753
Ok, i will go on this option. Thanks a lot bro for the help, i really appreciate again, Cheers
820
finnmorgan
finnmorgan
san diego
finnmorgan
audiobaun
    May 19, 2024
    May 19, 2024
