Amplifier/Subwoofer trouble
  • 2
squilko
I have 2 10" boss audio phantom series subs with dual voice coils. I have 3 different amps, all being 2 channel. I can hook each one up without any issues and i get a green power light, which is good. Whenever i hook up the subs the amp will go into protection mode.
I have checked all amplifier wiring and everything is fine. I have also taken the subs from the box and checked the wiring on them as well. I assured they are wired to the correct impedence and that all wiring is secure, but i still have this problem. I just cant seem to figure out what is wrong, any help???
The subs are dual 4 ohm voice coils. I currently have them wired to 4 ohms. I have a FUSION pp-am12002, BOSS chaos eXXtreme cx250, DC-200 depth charge by FULTRON
I would prefer to have the fusion hooked up
What size power and ground and how are your amp settings? I find it hard to believe that you're having trouble with 3 amps. I'd say you have a wiring issue(i.e. power/ground wires, most likely ground wire) if you're doing direct swaps and having trouble.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
You can't really set it to a specific wattage. What head unit do you have? Find out the pre-amp RCA voltage. Most amp gain knobs are based off of...
7
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Shallow mount subs like those recommended are a favorite of truck owners. Typically the space under the seat is wide but “shallow” from bottom of...
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
3K
squilko
squilko
Cincinnatti, OH
squilko
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
