Amps are staying on.....???
  • 2
jeeper2269
I recently made a trip in my Jeep and took out the speaker box that had the amp mounted to it. So, I unscrewed the amp, pulled the speaker wires and removed the sub box. I left the amp (teramps md3000) still wired, laying down under the back seat. This morning I found the Jeep battery dead. So, I figured out that both of my amps are staying on when I turn the Jeep off.  What is happening?
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
443
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
569
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
jeeper2269
jeeper2269
Somewhere, OR
nauc
