Amps Fine, Won't turn on? Never heard of this...
  • 1
Therabitier
I have a couple of amps, a Cadence z1502, and a Clif Designs 4 way 1400w. Been using the amps for 4 and 8 years with no problems ever, until 1 month ago. Here's what has been happening:
- When I began turning up the volume everything was fine, but when I turned the sub level on the deck (Kenwood, something just below excelon series and 8 years old) the amps would both cut out, and no sound. I initially thought I had fried them somehow (what the shop said due to my grounding against my spare tire area; Was no issue, ground works perfectly, no paint, clean bolted contact).
What I tried: I tested volts from power wire, 12volts, Remote wire, 12 volts, Ground, perfect.
BUT when I test them while inside the amp, they are all the SAME EXCEPT the power drops to 1.2 in the amp. When I tested direct power from my Voltmeter, the amp powers on! Viola! Not protected mode or anything. But it won't power up without that even though the end of the power wire definitely has power... Sound like a remote wire issue?
Has anyone else ever had this issue? Do I need a new deck? That's the only reasonable explanation I can come up with... Anyways, any help is very appreciated, since all my local audio shop wanted to do is sell me new amps claiming I blew them when nothing on the inside is blown and all fuses have been checked.
Ouch, you are right! So I won't burn anything? This is great news!
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
166
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
419
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Therabitier
Therabitier
Vancouver, WA
Therabitier
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
