Amps protecting
  • 2
Bass so loud it HZ
CarAudio.com Regular
I have two 10ks I lost one yesterday and I'm not sure why looking through the backplate I can't see anything burnt . I have solid electrical it wasn't overheated or clipped. I wired the all 4 subs to my one at 1 ohm today and it went into protect twice but came out of it. I never had these problems till I walled it. What could be going on? .I stay above 15volts amps don't get over 130 degrees. I ohmed my subs at at the amp and they ohm out . Wasn't playing below tuning anyone have any clues ?
Lower peak impedance or a change in where the peak impedance happens due to the wall.
Possibly . I'm running the surge 10ks tho I would have thought they could handle it . I was at half ohm giving them all they had before and no issues. I did go from grounds at the seat bolts to grounds from the alt but they test good and my voltage holds better so I don't think that's what it is. I did turn the gain up a bit but I never seen clipping. Maybe I need to turn it down a bit .. thanks !
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
155
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
