Amps that are Active capable
i going to try and go active with my amp also. i have a kenwood ddx812, it has time alignment, so if i put the tweets on the front rca and the mids on the rears rca, i can set my time alignment then correct?
seriously.. you cannot buy a good sounding amp with all those features for under 350 bucks with 100x4 and a excellent amp with those features is going to be well over 400.. take it from me save your money get a great amp and be done with it..
the best 4 channel with decent output and xovers is the SS reference.. there cheap now because there slowly making a comeback.. the 4.720 is slight over 350 and has a simple yet affective xover network and @ 13.5 volts it will do 100x4.. the next real step up would be arc or zapco ref..
i have an arc fd4100...50x4, or 150x2...musicality wise it is the bees-neeze but my current build with it will be my first attempt at hearing it bridged at 150x2 for just my front stage. but i do have 2 cross-overs per door on my kicker ss 6.2s and kicker ss 8"...i miss music in my car //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Even though he bought the Audiopipe, I would have to suggest the PG ZX450. Though it's rated at 75 x 4, they do ~111 x 4. You can get them on ebay for about $250-300 shipped for a good one. That amp has one of the most flexible xovers I've seen on an amp. So... yea you can buy a great SQ amp for under $350
An SQ MECAi competitor guy I know used to run Sundown amps and was getting docked points for noise in the system. It was traced down to the Sundown amp/s he was using. He was switching amp brands, but to what IDK. I haven't seen him for a few months now.
448
572
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Theride
Theride
NY
smgreen20
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
