Amps that does .5 ohms
Whats some good amps that does 1500-2000 watts at .5 ohms or the same at 2ohms.
There are no good 1/2 ohm stable amps.
A good amp, to me anyway, will have no noise, good onboard processing, and be reliable. Big watt D-Class subs amps are generally pretty noisy, have awful onboard processing, and no amp can be considered reliable when tasked with powering close to a dead short. I don't like 'em.
The question I have is why are you looking for a 2kW amp? You'd be really shocked what a good 5-800w amp can do compared to a lesser quality amp that has a higher power rating. Don't get too caught up in the numbers game as adding more power usually causes more problems than it solves...not to mention added expenses.
What subwoofer do you have and what kind of vehicle will this be installed into? You're much better off building a system around a particular amp or the vehicle than trying to make a certain sub work in your application as cheaply as possible. I say this b/c a good amp will flatter so-so speakers & subwoofers. A lower end amp can make really nice speakers & subwoofers sound like garbage.
yeah... i actually figure running the amp at 2ohms would be better than running it hard at .5ohms
now to find one that can do 1200-1500 rms at 2ohms, and under 300$
this if for a daily..
Car: 2003 Chevy Impala
Sub: Skar 12 D2 one for now but would actually like to go with 2 of them
Amp: Hifonics Brutus 600D the older model. running at 1ohms at 600watts
Box: 1.9^3 after displacement tuned to 33hz
would like to go with a 3.2 tuned to 28 with 2 of the Skars running around 500-800watts each
I couldnt DISAGREE with this more... MMATS makes mono blocks that are .5 stable, such as the 2000.05, the 3000.05, and the 3500.05. Some of the best mono blocks made. On-board processing is only necessary if you do not have an external crossover/EQ or a good deck. A lot of Class D amps sound close to if not as good as old school A/B amps. Ask anyone who uses the JL HD line...
Yeah lol I couldn't dissagree more either....plenty of good .5ohm stable amps...they wouldn't be rated for .5ohms if they weren't made to handle it. And like above mentioned onboard processing does not happen get a good HU. I've powered 6 subs each at a .3333333_ ohm load on my amp and it has had no problems...sounds good, stays somewhat cool still.
AP1500 is going to be your outright cheapest option. SS DTR towers are .5 stable as well
the DTR3400.1 is .5 ohm stable, so isnt the TX2600.1 i believe it is, the rest are not rated .5 ohm stable.
Let's pretend that the MMATS amps you speak of are pretty good. Will they last as long as long running .5ohm as they would 2ohm? No. Will they produce more distortion at .5ohm than 2ohm? Yes. Will they be noisy? Most D-class sub amps are very. Are the crossovers & DSP contained in HU's any good? Hardly.
The JL HD line does not have an amp that is .5ohm stable nor capable of 2kW. In addition, they're not exactly within the budget of the OP now are they? (under $300)
Since that line of amplifiers are not .5ohm stable, my statement is still valid. I've never come across a .5ohm stable amp that sounded any good, had good processing, or was reliable. In 10 years time you won't see too many of these things selling in the used market like you normally see with old school amps. Running at those kinds of current levels put an immense strain on the amplifier's power supply as few take the steps necessary to supply it with stable voltage and they suffocate themselves. And playing music at those low impedances is dangerous as a speaker's impedance can 1/2 itself. So while those big power D-Class SPL amps may warm up a 1/2 ohm resistor nicely, the game changes when you hook it up to a speaker.
For SPL burps & whatnot, those amps are fine. For everything else, there are better options...like those JL HD's you mentioned.
But 2kW for $300 new? That amp, without question, will be a POS.
155
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
cyn
cyn
Orange, Texas
Ken kong
    May 18, 2024
    May 16, 2024
