Amps
  • 2
Ok- if you have 2 SVC 4 ohm subs the lowest possible ohm load you can achieve is 2 ohms mono. You can reach this by wiring the subs in paralel.
AS for the amp, I would suggest that you look into some alternatives of a little higher quality.
Start with some of these:
JL Audio 500/1
MTX 4250D
Harrison Labs AE400.2
Alpine MRV F1507
Take it easy,
-zane
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
158
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Cadillac
Cadillac
Charleston West Virginia
zane
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
