amps
Are you looking to purchase an amp, or just to get some info?
The reason I ask, is because this is currently posted in the classifieds WTB section.
hey guys are the Crescendo amps good, i'm looking at the 3500, and i'm also looking at th AB VFL500.1, got 3 10's 1500rms each....
I'd go with the AB for sure... Crescendo is ok in my opinion. You can't go wrong with AB. I believe it's rated: 1 x 4700W @ 1 ohm on 12 volts. That should be perfect for your 10's.
[quote name='dewayne22']hey guys are the crescendo amps good, i'm looking at the 3500, and i'm also looking at th ab vfl500.1, got 3 10's 1500rms each....[/quote]
@nasty08impala ;
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
448
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
572
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
dewayne22
dewayne22
Indiana
unrreal sounds
