Amps
  • 2
Hello there,since I put my system in my car battery is dead when it sits overnight.ive changed the battery,alternator,voltage regular,added a yellow top optima with an isolater,still the same results.Noticed the ground on one amp went to the other amps ground then to the chassis.Is that ok like that?or should I ground each amp separately?Everything is hooked up correctly!Oh by the way it’s an older 06 mz e350.....I’m lost
TAKE YOUR ADDRESS OFF OF LOCATION.. check lights on amps if they stay lit an hour after they aren't wired to a remote turn on or they aren't connected to switch power (small blue wire should be hooked to something that comes on when u turn the key) other than that u have a grounded wire somewhere (naked wire touching metal)
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
429
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
561
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
John Garcia
John Garcia
5899 Hillview ave
BOOMINGRANDPA
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
