jjbeenken 10+ year member
Description:
Amptech 125-se c-series with 5600 stealth voltage regulator
Amptech a Product of M Power Manufacturing, LLC - Home
125-amp 12 VDC model
SAE continuous rated output for high temperature bulk charging applications
Marine certified - complies with Coast Guard and BIA standard, Title33 CFR, Part 183, Sub part 1, section 183-410 (Ignition protected)
Isolated floating ground to protect against electrolysis
6 x 50-amp high voltage diodes
14-guage hand wound stator
Precision balanced rotor
Extended life copper composite brushes
Heavy-duty bearings with high temperature grease
2 x 5/16" cable posts
Hand crafted in U.S.A
High Performance Regulator Delivers solid regulation and high charging current from high output alternators. Fast recharge time and stable voltage regulation for good battery performance. Voltage is sensed directly from the batteries
Rugged construction Long service life, corrosion resistant anodized aluminum heatsink. Electronics are sealed in epoxy compound. Regulator can be safely mounted in marine engine rooms.
Short circuit protection. Reliability The regulator circuit is protected against damage from a shorted field circuit.
High quality components Will regulate very large alternators. Uses a 30 Amp Motorola output transistor. Can regulate 300 amp alternators easily
Indicator light circuit Simple indicator on engine control panel. Will connect to existing alternator lights to give an indicator at the engine control panel. Installation is simple and straight forward.
The Stealth Regulator senses battery voltage directly so that batteries are charged quickly and completely without over charging. Designed to work with AMPTECH high output alternators or any externally regulated "P" type alternator.
USED FOR AROUND 30K MILES IN LAST VEHICLE, GREAT FOR SMALLER VEHICLES.
$300 PLUS SHIPPING OR WILL CONSIDER TRADES FOR DAMPENING MATERIAL
