Any APT-X bluetooth rumors?
  • 2
CZ Eddie
Has anyone heard anything about any head units coming out soon that have the APT-X lossless Bluetooth codec? For hi-def wireless audio from our phones to the car stereo?
What is APT-X?
It's Bluetooth for "Audiophiles".
APT-X Lossless supports high-definition audio up to 96 kHz sampling rates and sample resolutions up to 24 bits.
  • Key Features
  • Compression ratio: 4:1
  • Audio Format: 16-bit, 44.1kHz (CD-Quality)
  • Data Rates: 352kbps
  • Frequency Response: 10Hz to 22kHz
  • Algorithmic Delay:
  • Dynamic Range: 16-bit: >92dB
  • THD+N: -68.8dB
If I had to guess, normal A2DP Bluetooth might sound as good as a 96kbps MP3 file. While APTX Bluetooth sounds as good as a 320kpbs MP3. Essentially, to the trained ears it is a HUGE difference in sound quality.
"Normal" Bluetooth streaming music can sound great. Most of my mp3 collection is no less than 256 kbps. I've heard an improvement when going from Bluetooth to the same files on USB, but it's not nearly as bad as you're saying. That said, it does depend on both the Bluetooth in the portable device and the Bluetooth in the head unit. They both have to be good enough.
edit: Regarding APT-X, I have not heard any news about this for aftermarket car audio.
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
812
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
5
853
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
CZ Eddie
CZ Eddie
Austin, TX
trumpet
Decebal
    Jun 10, 2024
