Any caveats regarding fixed box to chassis?
Sn4ppy
CarAudio.com Newbie
I have plans to fix the box directly to the sheet metal of my trunk..
Originally I intended to incorporate the backseat firewall as a wall of the box along with some dynamax dampening material but figure although corregated the metal won't be significantly dense enough to match the 16mm MDF of the rest of the box.
But will this quell or amplify rattles? Is it common at all or something I should steer right clear of?
Metal panels in a car are not sufficiently rigid for subwoofer enclosure and building it up with fiberglass will be rather expensive and permanent as opposed to just building a normal wood box and just securing that with some brackets or similar.
Definitely mindful not to drill through floor into any lines/cables on other side of metal or worse diesel tank but I think there will be value fixing this to the vertical plane as well as horizontal.
I'd like to avoid a false floor or subfloor because this won't be a huge box and I'd like to maintain access to spare tire, the rest of the trunk space and keep the excess weight down.
Thinking t-nuts and urethane washers on other side of sheet metal under bolt?
And lots of lock tite
Use the vibration loctite
I just built a system not long ago in my 2008 C300. I actually cut out the partition behind the arm rest in the rear seat to act like a port. I...
7
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
It is the same one that Rockford Fosgate sells as well. They are identical and the NVX is cheaper as well. Even Amazon has them iirc for 199.99...
12
Did the instructions on the back of the main module not work? They are vague but give you a general procedure.
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
Sn4ppy
CarAudio.com Newbie
Sn4ppy
VeganAcademy
KicktheSDbasshead
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
