any help on optidrive amps or audiopipe 1800s strapped.
seems like it would be better to just buy a .5 ohm stable amp that would provide the output you seek. This one appears to be designed to be efficient at .5ohms, based on the almost doubling of output from 1 ohm to .5 ohm. A very impressive amp for the $.
Lanzar OPTI4001D 4000W RMS Monoblock Class D OptiDrive Car Amp
hey we agree ,just get an amp that does what you need at 1 or 2 ohms.between the 2 amps your looking at ,the opti hands down
ps Lanzar is one of the only ones I am aware of (there may be others) that build a true .5 ohm stable amp and stand behind it. This would allow for safe 1ohm strapping on the .5 stable amps as well.
i believe crescendo stands behind their .5 ohm as well
yea these amps are beast and .5 ohm stable.one of my friends say the bigger ones on volt sensitive if they drop below 13 or 14v they will fry Very quickly. my friend ONLY uses lanzar is a auth dealer. also the amp i have is .5 ohm stable as well and is rated at .5 ohm, also a few people have burped them at .25(im not).
my sub is dual 2. was told by psi it is a duel 1ohm.( i guess all the dmm ive checked the sub with are lying to me) anyway. im thinking i might actually need a 4600opti to deliver me the 3k rms i am wanting.
Lanzar and Crescendo are both solid amps. Much nicer than any audiopoop. Hard to get that kind of power for less than 5 bills in a quality amp.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
496
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
540
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
575
mtxfan4life
illinois
VWBobby
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
