anybody know how to...
  • 4
basswiigee
MICHIGAN
ok, i have a 05 cobalt, everything inside is either hushmated or dynomated, yet i get the most annoying rattle from under the car... it has some type of aluminum heat shield, does anyone know how to stop this rattle or if they sell more sturdy heat shields??????
is that safe ? lol
my car and my buddies car have the heat shields removed due to an annoying rattle. no problems so far lol.. mine's been off for almost 2 years now.
you can also try to tighten it back up.. it could be a little loose.
it looks like its spot welded, i'll check it out... thanx...
Usually you can just bend them or crimp/crease them to get the rattling to stop... But I would check all of your exhaust mounts/hangers/brackets because a lot of times that I get heat shield rattle complaints; it's due to the exhaust being able to move around too much from a broken or worn out mount... Just something worth checking out while you're under there //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
3K
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
8
PURE AMPLIFIERS | ADDICTIVE AUDIO, INC. (addictiveaudioinc.com)
basswiigee
basswiigee
MICHIGAN
NIHL8ION
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
