AQ/SQ speakers, and or tweeters?
  • 2
jflick092
Work Do'er
154
Ohio
I'm looking to upgrade my speakers in my car, I was looking at an MBQuart OA800.4 thats 100x4, I was thinking of getting either (4) QP-MR6.5's, or (2) QP-MR6.5's and (2) QP-TH25 super tweeters.
What do you think would sound better/ louder? I'm afraid the two speakers in the back wouldn't be noticed as much, but I also was wondering if I could run the speakers and tweeters off the same amp, and if a crossover is necessary. The amp has a HPF that can be adjusted for 2 channels.
Also I have no where to put the tweeters right now cause factory are only 1". I also read not to go much over 2.5" for mounting depth on door speakers for my car and the 6.5's are around 2.9"
Any help is greatly appreciated.
If anyone's interested I ordered a set of each, and the oa800.4, built a box for the tweeters theyre on my rear deck now. The 6.5's had such a big magnet that it hit the door support and wouldnt fit. The mounts were also slightly bigger than stock so only two screws would fit. Mounting depth was fine the magnets just to wide for a fit so I'm thinkin about getting some polk db651's //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif... Even with just these tweeters, the highs are much more clear over my hdc315.
Can you use mdf to use all the door's mounting holes, then svrew the speakers to the board. It will also help with the mounting depth.mostly depends on the door panel design if this is possible.
If you decide to sell those Polk MM Series Eggshapes before you blow them.. Let me know 👀 👀
7
That's what I was thinking of running at 16 gauge thank you.
29
If I were running an amplifier I would place these in either the existing location with some abs cut out to fit or in a pod on the dash...
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
165
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
179
jflick092
Work Do'er
jflick092
Ohio
sam_b03
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
