are lanzar vibe amps really as good as they say?
Lanzar isn't quite top of the line. Their opti line gets good reviews but vibe, no.
For $225 you're not getting 1600 pure watts from any amp. Rule of thumb is you get what you pay for. I'm afraid you'd be dissapointed if you put that amp on your subs. Be sure you buy from someplace with a good return policy before buying anything over 200 bucks.
Hope my two cents add up.
Originally posted by southernbandit20:i was looking at some lanzar amps and they were like $225 for like a 1600 watt amp. i have always been told unless your paying factory coast for it then if you pay less than 50 cents a watt then you are not getting what it says!
I've got the lanzar 1200D and so far it's working fine for me. I would recommend the 1200D if you're on a budget like I was. However their lower grade vibe amps aren't all that great but again, if your on a budget they will probabaly be fine.
The Opti Lanzar series is a good series however.
Not a family member here....but I sure as hell felt like one as I devoured this thread. The ONLY REASON I vandalize this tapestry of broken hearts...
22
4K
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
117
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
160
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
417
southernbandit20
southernbandit20
LegendZ28
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
