Are these the same????
  • 4
2 Guard
I finally got a chance to listen to the Morel Dotech Ovation comp 6 an i like them for my new setup. As i'm serching around i also found the Phoenix Gold Ti6 Comp Elite. They look to be the same mid-driver, not sure on the tweeter though.
Does anyone what the difference is between the 2??? Is the sound between the Morel and the PG the same?? or close enough to were 1 might not know the difference.
Thankx for the info.
the pg are Morel made, but the specs are a little difefrent.
Aslo the tweeters are different. Still both great mids..
The PG ones..
the PG
Complete 2-Way component system
300 watts RMS power handling
Ultra-thin mounting depth
3 inch multi-layer voice coil
Audiophile grade external crossover
Solid one piece polypropylene cone/dust cap assembly
FEA optimized inner-radial neodymium motor structure
Custom cast aluminum basket
Midrange Sensitivity 89dB (1w/1m)
28mm hand doped tweeter
Integrated phase plug for enhanced dispersion
Crossovers features state of the art computer aided design process for uncompromised fidelity
Shielded Titanium crossover housing with gold plated speaker connections
Audiophile components: air core inductors/composite bypassed capacitors
System includes pair of 6.5" mids, pair of 1" tweeters and professional crossover
Specifications
Tweeter Mounting Depth: 1.125"
Midrange Mounting Depth: 2.2"
Midrange Mounting Diameter: 5.5 - 6.0"
Crossover Housing Dimensions: 9.75" X 6.25" X 2.0"
Frequency Response: 20Hz to 20kHz
Nominal impedance: 4 Ohms
Acoustic Crossover Slopes: 24dB per Octave
SPL: 90.9dB
The morel
Nominal Impedance: 4 Ohm
Power Handling: 160W
Max. Transient Power Handling: 600W
Sensitivity (2.83V/1M): 91dB
Frequency Response: 35-25000Hz
Crossover Point: 1800Hz
Voice Coil Diameter
Woofer: 54mm (2.1")
Tweeter: 28mm (1 1/8")
Voice Coil Wire
Woofer: Hexatech Aluminum
Tweeter: Hexatech Aluminum
Magnet System
Woofer: Hybrid rear vented
Tweeter: Neodymium
Mounting Depth
Woofer: 61mm (2.37")
Tweeter: 20mm (0.8")
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
701
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
6
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
No different than powering multiple amps. I'd use a fused distribution block. Power each amp. Probably easiest to just add that to the existing...
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
7
2 Guard
2 Guard
P.H.X AZ.
2 Guard
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
