Ascendant Audio?
We can take care of them for you. We don't have the CF dustcaps, but we can do recone kits for them.
Looking at ~75 a piece for a recone + shipping.
Thanks!
-Nick
they can use the dustcaps on them if you have them, or least scott said he could as long as they were in good condition.
i typed it and it didnt work, even searching on yahoo couldnt find it but thats it tho. i wouldnt mind having them reconed. they both are in very good condition with a lil wear on the surround foam. but i believe the voice coils may have burned out. as when i did use them as soon a a bass note would drop it would pop the protect on my Hifonics Brutus and at very low volume sound like a pocket full of change.
ALSO what is the power rating to these subs? And enclosure size? i bought them about 3 years ago just because they were recommended very highly to me but i smoked them about 2 months into having them
Rated at 800W continuous. Workable enclosures would be maybe 1-1.25 cubic feet and 2.5-3 cubes tuned 30-28 Hz. Something like that should be fine.
but see i had a 1k watt amp and ran them at 500 a piece and they sounded good. then i bought the brutus and hooked it up and ran it bridged at 2 ohm, didnt think id smoke em tho. they came with no info when i bought them 2-3 years ago. i was surprised as i replaced them with Alpine Type ARRRRR's and beat the snot outa those at the same amp levels for 2-3 years. guess ill have to build a better box for em and use less power once i get them reconed.
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
180
86Montess
86Montess
Clearwater, Fl
newusername
    May 31, 2024
    May 24, 2024
