ATOTO F7 XE head install in 2003 Toyota Sequoia
  • 2
JVH
This last weekend I removed my failing factory radio and replaced it with an ATOTO F7 XE unit.
The install went fairly simple with the addition of a JBL amp adapter cable and side install bars from Crutchfield.
I am curious if anyone else has installed this unit. I am finding a few idiosyncrasies in the operation that I need to work out.
IE. when turned on the power antenna goes up. When I turn it off it doesn't go down until I turn off the ignition.
Thanks in advance.
The install
I just installed the same on my 2004 Toyota Sequoia with JBL. I have noticed the same thing with the antenna so I’m also curious to see if anyone knows a solution. I’m also getting some quiet background noise when the volume is all the way down.
Where did you get the faceplate that goes around your stereo? I need to find one to cover the gap.
Thanks!
Been doing testing all day and setting up gains and playing with crossovers through the DSP. This cheap head unit isn’t too bad at all. Touch...
I have had an absolutely horrible experience with Atoto head units. I bought the A6 10.1” pro a few years ago and within like 8 months the thing...
Hi guys just new here ive joined as ive just bought a atoto s8 premium double din android unit i have a 2018 vauxhall vario van ive bought a...
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I...
JVH
JVH
Kansas City, KS
Seq
    May 18, 2024
    May 18, 2024
