AUDIO HC 15
  • 3
Firstly, you need to be sure the voice coils have been fried.  Test with a multimeter to get confirmation.  The reason I mentioned so its not your amplifier that has stopped functioning for some reason :uhoh:
Once you have determined that it is your subwoofer ,then get online to see speaker repairers closest to you so you can obtain quotations for the work.
Good luck with it and hope you determine the culprit and then take steps to rectify it. If it is your amplifier, then go shopping for another one, mate!
HC? That's gotta be Resonant Engineering...old sub you got there. . When they 1st started, they had a few lines out and HC was one of them. As DrBoom stated, check both coils with a DMM. If you don't have one, they can be had for 5-10 bucks. But a regular household battery is another great way to check voicecoils on a sub.
A Link would be very helpful. Id be interested in taking a look at some gear
162
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
278
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Rob Medeiros
CarAudio.com Newbie
Rob Medeiros
Boomin_tahoe
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
