Audio install - troubleshooting
  • 1
ThumpNoThump
CarAudio.com Newbie
Usa
Hi all,
In the process of adding a sub and new speakers to my 5th gen RAM. In terms of what happened, I installed a 2x10 sub and it's running fine using the anc bypass. When I was swapping out the 6 factory speakers and after doing the sub I started with the front and dash speakers (so 4/6 speakers). I wanted to take a cheeky peak at hearing how different the new fronts vs old backs were. When I turned the tunes on, there was no sound at all from the back. If I ran 100% to the back on the fad/balancer option there was just a small amount of volume out of the fronts but 0 from the back. When I go back to center and I can hear the front 4 just fine. Figured maybe there's some sort of ohm mis-match going on or something so I continue. I've put the new back speakers into the door and still no sound coming out of them.
Pretty down that after all the hard work that I now need to troubleshoot. The problem occurred either during when I was running the power cable for the amp from the battery down to the channels at the side, or at some point when I was swapping out the front 4 speakers. In terms of trouble shooting, I've tried with the ANC bypass / amp and without and it's still just 4/6 speakers (i.e. testing if it was the bypass harness and subs doing the short out). Any audio folks able to chime in on how to troubleshoot this? You'd make my day if you had any advice.
Rockford Fosgate R2-750X5 I just bought a audiocontrol converter and hopefully that will help
982
A Link would be very helpful. Id be interested in taking a look at some gear
161
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
278
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
ThumpNoThump
CarAudio.com Newbie
ThumpNoThump
Usa
ThumpNoThump
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
