Audio Technix Strato 15" D4
Does anyone have experience running a single Audio Technix Strato 15" D4 or any other strato? Would just like a review or feelings on this before I pull the trigger and order tomorrow! I'm going to be running with a JL 500/1 and have a custom enclosure built for the strato. Any help is much appreciated! Thanks!
I want to get the 18 never had an 18 before I hope there are Still some left next week //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The 18 would be sick! How big of an enclosure would I need for the 18"?? Anyone know if that would fit in an '04 Hyundai Tiburon? If yo would know the answer and need my trunk dimensions I can go measure!
Lets see some dimensions!
Take the trunk opening into consideration. Trunk space is useless if the opening isn't big enough to fit the enclosure
Are you talking about for the height on account of the slope in the hatchback? The 15" is the lowest point with that taken into account.
I need help in deciding to order the 15 or 18! If an enclosure for an 18 will fit then I'll probably go with that. Please help!
You've got about 8 total cubic ft. from your dimensions and 15" for height should be plenty for that 18. I'd get a box designer on here like pro-rabbit or double07 to design you something or see if it's even going to fit in there after it's built. I think you'd need at least 5.5-6 cubes to run an 18. I've decided since the "blowout" sale to try a couple 12's. Can't beat the price and they look impressive on lower power.
you would most likely have to build the box INSIDE the truck (as opposed to building it then dropping it in) due to the trunk opening.. ported the 18 needs 6 cubes.. your trunk is 8, you will never get that box in there unless built inside.
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
rhinoky
rhinoky
Cincinnati, OH
rhinoky
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
