audio upgrade
  • 1
kennethvd1997
CarAudio.com Newbie
I am looking between car audio equipment and would like to get some information about how I best apply it.
I have a bmw z4 e85 with 10 speakers. 2x OEM tweaters, 2x oem 16.5cm speakers at the feet, 4x mid range (2x in the door and x2 behind the seat) 30w rms / 60w peak 4ohm and 2x oem mid range behind the head rest.
These are all connected in the head unit without an amp. I have a subwoofer installed in the trunk (KSC-W1200B) 300w rms / 1200w peak. I've had a short in the amp that came with that sub, so I need a new amp anyway.
Now my problem is if I turn the volume up a bit louder than average it quickly becomes distorded and krackles.
Which speakers should I replace and what should I connect to an amplifier and what should i leave in the head unit?
And should I take a separate amplifier for the subwoofer or do I look for 5-channel amplifiers?
Thanks for the help.
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
I don't think OP is going to do the deadener themself, but these are my tools for it. If its 80 degrees out, you can just leave it out and it's...
7
3K
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
kennethvd1997
CarAudio.com Newbie
kennethvd1997
belgium
kennethvd1997
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
