audiocontrol 2xs with power wires
  • 1
mclerico83
tampa
audiocontrol 2xs
9/10
Concert Series 2-Way Crossover
Uses a steep 18 dB (90 Hz) per octave slope to separate your high and low frequencies
Built-In line driver improves signal from a weak receiver
One set of inputs and two sets of outputs (High-Pass and Low-Pass)
Built-In filter removes subsonics from your signal
Simple connection and setup
Balanced inputs reject noise caused by your vehicle's electrical system
Internal switching gives you other options for dealing with ground loops
Ground isolation selector allows you to change the power supply for different systems
Gold-Plated RCA jacks
Top-Mounted controls for easy adjustment
Frequency Response: 15-20,000 Hz
Signal-to-Noise Ratio: 115 dB
Maximum Output Level: 9.5 volts
Fuse rating: 1 amp
Color: Salmon Gray
Also available in: Sierra White
Dimensions: 1-3/16"D x 4-11/16"W x 5-1/2"H
60 shipped
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
744
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
6
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
mclerico83
mclerico83
tampa
mclerico83
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
