Axxera Radio USB Music Playback
  • 2
Curmudgeon10
CarAudio.com Newbie
I've a newly installed AVM82NAV Axxera that works fine. But I don't completely understand the way it treats music files on the USB Stick. I first learned that it will play all the common formats, not just .mp3. I tried three folders: two with a single name and one named "Classical Music." The two named folder showed up as "Not Supported." Do I assume that within a folder, a subfolder won't be recognized at all, or it will be recognized if it is a single name?
I direct copied my iTunes library to the USB Flash drive; more than 6,000 individual tracks well organized in a system of folders and subfolders. Before I spend the time to rename EVERYTHING, I'm hoping some forum members can shed a little light on what the radio expects to see.
Different radios can be tricky ...luckily I have access to many radio to play with ..but I've found the same thing as you on usb files some radios read them fine others say not supported ... I tried to help an older guy out several months ago with a new Ford truck ..and everything I tried said not supported ..they all worked fine in my truck ...an aftermarket deck ... and they worked fine in a double din I had put in his 93 Mustang..but nothing would play in his new F150 ...unfortunately I never figured out why ...they also played fine in my factory 2013 Dodge Dart radio ...
Hey there I've had this Axxera AV7336MB for years now, but it's got some issues and needs to be replaced. I went to go buy a new one, only to...
  • Locked
Will trade for pair of 6.5 subs or a single 10 shallow
Curmudgeon10
CarAudio.com Newbie
Curmudgeon10
Salisbury, MD
Louisiana_CRX
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
