b4 i getta wall build
  • 2
well if you set your window mirrors right the blind spot will be pretty small and you should still be able to see out of the second row windows. as far as backing up goes look behind you before you get into the car then guide yourself out with the side mirrors. i personally would do a wall in a daily driver but to each his own
i got an 02 maxima also so drive that more then the tahoe n its a 2 dr that was my only concern was cuz it does have the back doors thanks for the insight excited about the build
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
12
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
907
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
dub22
st8t bass
dub22
minot,nd
dub22
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
