The Camry
Hey, I Try.
What are all of you using for battery terminals? i need one with atleast 1/0(or bigger) input, 1(4awg), and one or two for factory small wiring.
man i have some great knu terminals, they great because they're "low profile" and have covers but omg they a pain to take off.. the screws are on the bottom so u have to stick all wires in it tighten them then mount it onto battery and the allen screw is very low on side each one takes me about 5 mins to get off be cause it's so close to other stuff.. anyway i'll show u those in case u have tons of room around your battery, if not get some gp audio 4 or 6 spot terminals others similar to those everywhere.. this is before i added big 3 wiresWhat are all of you using for battery terminals? i need one with atleast 1/0(or bigger) input, 1(4awg), and one or two for factory small wiring.
You don't need an ISO unless you play a lot with the car off. With the car running the ISO is bypassed.Plan on running a 2nd battery as well. Any recommendations on which? Also looking to add an isolator. Sonic has this. https://www.sonicelectronix.com/item_28365_The-Install-Bay-IB500.html?from=701
Looks like a good one.
