Batt Resting Voltage....
  • 2
DonH
So Cal
So what should the resting voltage of a batt. be? Dry cell that is... Listed on it says "stand by use" 13.6~13.8..... my dmm is reading 12.8.... is that what it should be? since my batt in my truck rests at that?
Standby use indicates charging voltage that should be applied if the battery is used for - wait for it.... standby use. Such as in emergency lights, UPS's, etc. Essentially everywhere that there is a constant voltage on the battery.
Cyclic use would be your car battery, which is charged every so often when the car is run, used when the car is started. This use does not have a constant voltage on it. Typically cyclic use is higher voltage to induce a shorter charge time. STandby use is lower voltage to reduce heat and extend life.
Your car batteries voltage is in the normal range.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
637
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
DonH
DonH
So Cal
bobdole369
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
