Batteries for SAZ-3500D
  • 1
Franky
5
Alaska
None of the "special" car audio batteries will work because the shipping for these are like the price of the battery itself //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif (at least the places that I've seen).
What exactly are the specs that I'm supposed to be looking at as far as voltage drop for the load of the amp? Are AGM's the only batteries that will really work?
The website "PowerStrideBattery" has free shipping to Alaska and I was looking at this battery "Odyssey 34R-PC1500T". So would 2 of these be sufficient for the saz-3500 (and probably the saz-125.4 later on)? Or can I go smaller or will I be forced to go bigger? These would also be the starting batteries and I would like 2 of what ever type of battery I get because of how I'm installing them. Thanks in advance //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW sorry but it wouldn't let me post a link to the battery...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
161
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
9
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
Franky
Franky
Alaska
Franky
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
