Battery - Alternator HELP
sorry. just wait a little bit, see if it goes away. the alternator has the same plug as your stock one does, right? If it doesn't after a couple days you may need to go into the auto parts store and have them put it on a scan tool to clear the code.
What the ****? Are you trying to put ohm's law into very complicated verbiage?
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
I'm not an expert on Lithium by any means. All I can say is I've played my system for about 2 hours at about half volume(20/36 on the headunit)...
cbuts
cbuts
canada,ont
cbuts
