Battery wiring ?!?!
  • 6
bgordon
160db bound !!!
Would it be ok to wire two different batteries together. I have a duralast gold group34 up front and a yellow top group 31 in the back. Can I wire them in parallel together instead of having to wire the 2nd battery straight to the alternator. I just wanna make sure the duralast won't mess up my yellowtop and I definitely don't want a fire.
Thanks
Is the gold an AGM? if it is not do NOT mix the two. If they are both Glass mats you can mix them, but two different batteries will still affect the life of each other. I dont mix different batteries personally.
I'd be more worried that the Optima battery would wipe out the good one you have. ;-)
And yes, you can parallel them regardless of technology. It's better to run all AGM batteries if you have any but nothing will catch fire. You just won't have as high a resting voltage if you mix AGM and wet cell batteries.
nah I wouldn't, put in an isolator or sumthing between the two. it's always best to run the same batts (same age too) one batt will be better than the other (no matter what batts they are) and the weaker of the two wont last long
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
As I sit and Stare at this Pic. I keep thinking to myself of how easy it is just to drill a hole in that + battery connection as it looks as...
4
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
495
bgordon
160db bound !!!
bgordon
Central Kentucky
Side Show
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
