4runnercrazy 10+ year member
Mattchu
so if i have dual12's that each are wired to 2 ohms can i bridge each sub to a 4 channel amp or would there be a mis-match in ohms
its a 4 channel amp, that wont worksounds fine to me as long as the amp can handle 2ohm stereo load. A better idea tho would be to wire the subs up in series to 8ohm, then wire the subs together in parallel to get a 4ohm mono load
thanks man2 ohms will likely smoke the amp.
8 ohms will work, you just won't get any power.
its not me a while back all the avas got changed to that, i just have been too lazy to fix itcan u downsize ur ava...it scares me a bit...i hope thats not u
