Belva Sub Package
  • 2
TanyaTheTiburon
NJ
How's it goin guys, this is my first post on this site, sorry if its in the wrong place. I was looking at cheap 12 in sub packages (2 12's, amp, enclosure, wiring), and came across this one by a brand named Belva. I tried to research this product, but it seems no one has truly reviewed it. And yes, I understand it is not high grade, I'd just like a setup that works. Is this cheap price to good to be true? Or has anyone experienced these subs/amp? Thanks in advance, sorry if I'm a newb. Btw, they'll be going in an 04 Tiburon gt (if that makes a difference at all).
http://www.amazon.com/Belva-BPKG212v2-Complete-Monoblock-Amplifier/dp/B0190MP01M/ref=sr_1_2?s=car&ie=UTF8&qid=1455422026&sr=1-2&keywords=12+in+sub+in+box
Thats pretty dirt cheap for a packaged deal.. Belva upper line of subs are not too shabby and amps.. This is a more entry level/low grade setup for those needing a little bit of bass.. Dont expect eye squinting effects or hair tricks or hitting some real lows, like Decaf or Dubstep and expect hair tricks/ect. but for some added bass missing within a stock system it will be just fine for a small budget .At the least you may want to get the big 3 done(search you tube for details) in which Id recommend on any vehicle and maybe see how your electrical keeps up with that amps draw.If it draws too much,simply keep that big 3 and add a decent agm battery and you shouldnt have any issues of lights flickering ect and maintain voltage..not a bad entry level set up for the price though. just my 2cents
Yeah, entry level is fine with me lol. In the description it doesn't list the amps specifications, so I'm not quite sure as to how much power it draws. The Tiburon GT already has an amp that powers the four speakers (and 2 tweeters). Would I be able to simply hook up another amp (the one in this package) solely for the subs?
227
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
553
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
583
TanyaTheTiburon
TanyaTheTiburon
NJ
TanyaTheTiburon
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
