benching amps...
  • 4
Not unless you have a power supply that delivers at least 20 amps...Can also be done with a battery and a trickle charger. Make sure it is fused....Have a set of speakers mounted on a bench for the purpose and a head unit with an antenna....I sell quite a few amps on Ebay and you always get better bidding with a fully tested unit.
how is this done? can i do it myself?
Depends on what you are "bench testing". If you are "benching" it just to verify that it works, then you can do as described above.
If you are benching it to determine the amplifier's actual output, then no, you generally can't do it yourself as it would require components that most people don't have access to such as an oscilloscope, large 12V power supply (much larger than 20A....100A+ depending on what size amplifiers you are benching), large dummy load, etc etc. Best to just find a local shop that already has all of the necessary components to do it for you.
could you, the above poster, or someone else check this out? would be much appreciated //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
http://www.caraudio.com/vb/showthread.php?t=129304
yea... i figured that squeak. just wanted to see. and yea, i wanted to test output. guess i do need to look into shops around here. thanks bro
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
371
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
518
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
_DjScrew_
_DjScrew_
omaha, nebraska
_DjScrew_
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
