Best Amp for single 12” Fi Alpha
  • 4
Megadave06
4
Looking for opinions on what budget amp would be best with a Fi alpha 12. It’s going in a 1.4 cu ft sealed enclosure under the seat of my 17’ Silverado crew cab. Looking for something that can be played for a couple hours at a time without overheating. I’m thinking 800w RMS would be ideal and I’ve narrowed it down to these three (but open to other options)
Soundqubed S1-850
Skar RP-800.1d
Pioneer GM-D8601
Soundqubed S1-850
Skar RP-800.1d
Pioneer GM-D8601
SoundQubed gets my vote of the two.
Or even the Synergy 1k: https://store.soundsolutionsaudio.com/products/synergy-audio-efa-1k.html
Thanks for the suggestions guys, that synergy looks like a good amp too, and is on sale for $129 on their website. After researching a lil bit...it seems like I should have an amp that has a slightly higher rms than the sub. Does the sealed enclosure affect this as well? Should it be even higher rms? What would be ideal...1000w or 1200w?
the synergy is a nice amp but if u wanta stay cheaper and u sure u staying sealed u can get the pioneer 9601, pretty cheap and it really does 1200rms.. just set gain low but if u ever need more power u will have it., they are decent amps.. they just don't have ss filter which i recommend for ported boxes but u won't need that.. if u think u will want sub to be loud and may get ported box later get a good 1k-1200rms amp that has ss filter (even audiopipe 1500 does about 1300rms $128 or so) on thses higher rms amps u would wanta set gain low but gives u "headroom"
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
10K
Megadave06
Megadave06
BOOMINGRANDPA
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
