best amp for this match???
I have an mmats 3500.05 for sale.. if you wanted to run one amp per sub, this amp would do it good and is crazy efficient.
says its only stable down to 1 ohms and 2 ohms daisy chained
Clamped amps forums
Check out the 3500.1d, ignore the ones that aren't strapped as they are the v.1.
As you can see they have clamp number for strapped at 2ohms and strapped at .5ohms.
Strapped at .5 they were pushing about 4600 per amp, after .9 rise at 10.5 volts. Solid clamp numbers.
Strapped at .5 is like running each amp at .25.. So you can definitely see they will run at .5ohms each no problem.
Two AQ's is more than two HDDs will need, and then some.
https://audiolegion.com/collections/monoblock-amplifiers/products/al1200-1d-1200-1d-monoblock-car-amplifier
7
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
11
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
vibe
vibe
Prescott, AZ
Bwap
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
