Best Enclosure For a 96 Chevy Silverado ext cab? (pair of alpine type r dv2
  • 3
UncleScooby
CarAudio.com Newbie
hello everybody i have a 96 silverado ext cab no back seat so i have roughly 34t x 24d x 50w in space to work with im using two alpine type r dv2`s with a hiphonics brutus 3000.1d which gives them the 750 rms each at 2ohm just not sure on box design like which way do i want subs facing where do i want port facing doi want slot or tube????????
I would put those in 3.5-4 cubes tuned to 32-36 HZ with an aeroport firing to the passenger side. Single 6 inch round or dual 4 inchers depending on how it all works out during designing. You could also do a forward firing slot port in the center of the box with the subs on either side. You could side fire a slot port, or downfire the subs and port. The world is your oyster after you figure out air space and port tuning.
On a sealed sub box if I faced the subs up, I lost quite a bit of bass. Faced them forward, they worked great.
On a ported box with subs and port on the face, up or forward did not make a difference. Only reason I face them forward is to prevent something from falling in the port.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
625
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
930
UncleScooby
CarAudio.com Newbie
UncleScooby
Phoenix Arizona USA
1aespinoza
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
