beware of lanzar amps
SPLkid
i was going to purchase a lanzar amp for my system because the specs were exactly what i needed until i notice that the spec listed on the website were different than the ones in the manual. the spec was 400x2 at 4 ohms but when u read the manual it its only 125x2 at 4 ohms come to find out they only list the 400 for advertising to draw u in so instead i bought the power acoustik 1800 gothic series.
Opti line is good (old Opti's are Zed made). Otherwise they're complete shite.
Also AFAIK OPTI4000 is same guts as Soundstream XXX6500 and OPTI 6000 is same guts as Soundstream XXX10,000
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif no way
Not a family member here....but I sure as hell felt like one as I devoured this thread. The ONLY REASON I vandalize this tapestry of broken hearts...
22
4K
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
168
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
419
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
SPLkid
SPLkid
chestertucky ,michigan
n2audio
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
