Big 3 using 4 Gauge ofc
  • 2
Jimg
CarAudio.com Regular
217
13
Using a max of 2000 watts
is 4 gauge OFC wire large enough for the Big 3 Upgrade under the hood.
Thought about using 4 gauge for more ease of use with the wire lugs around the alternator and easier to bend around the motor under the hood
I will be using 0 gauge for my power run to the back of the car where I will have the distribution fuse blocks to the amps.
If need be I will also have a battery in the trunk of the car.
That being said is 4 gauge enough for the big 3
Bigger is better, but 4 will still be an upgrade over stock. If you leave the factory wires in place, you'll likely be close to the equivalent of a 0.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
8
Jimg
Jimg
jt4x4
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
