Big screen HDTV in Van
Gary S
So I'm thinking about building a car audio demo van...........I want to use a cargo van, bolt down the rear doors and put a big screen TV right across the rear doors...........maybe a 32".......... how can I do this? A 12 volt to 110 volt converter? will it handle the load?
The first problem I see, I don't think car audio gear is compatible with HDMI wires?
I took a quick look at sonic electronics, the biggest monitor they have is 9"......that's not a big screen.
Model numbers or links to products would be appreciated.
This thread is a bit dated, but since noone responded I wanted to ressurect it. I've got a 2015 Transit that I've converted into a motovan and have a 32" LCD mounted. I'm in the process now of a stereo build and was wondering if anyone could provide some input on how to get the TV connected to the head unit...or possibly direct to the amps??
Output options are HDMI, Digital Optical or headphone jack.
You might need to get a DSP
My 360.3 has an optical input on it .
It would help if you listed the equipment your are running or thinking of running.
If your replacing your HU then you can look for one with a optical input.
There are a few that have them but your options are limited.
I've personally never seen anything with HDMI car audio wise but maybe someone else has.
Stay away from the headphone jack
Tks Kickstand- I went a bit simple on this build since it's for the van and not a daily driver. Atoto F7 Pro HU and hopefully using some old Precision Power amps and a Coustic x-over that I've had in storage for about 20 years.
The F7 doesn't have anything other than an Aux input that will work. Since posting this, I started thinking about an HDMI to RCA adapter and using splitters at the amp. Something like these guys:
HDMI to RCA converter
Splitter #1
Option 2
Thoughts?
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
Gary S
Gary S
Ex JL Audio Rep
Cru
