Birth sheet for RFP 360.2 ??
  • 1
I have heard that the birth sheets for the Rockford amps vary from amp to amp. My punch 360.2 which is almost 3 years old was tested as 490 watts RMS with the gains turned all the way up. I do not have the sheet in front of me so I can't get any other details.
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
Here is a chart that gives you relative cone size. Diameter of speaker*|*Cone area of speaker in square inches 18"*--->*254 15"*--->*192...
15
3K
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
Tryin2bump
Tryin2bump
Michigan
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
