You have fancy food on your wire to tell the difference between POS and NEG //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifI use the same color positive and negative power wire, but I have different gourmets on each one to tell. You gotta be smart.
SIG WORTHY!what exactly is the little squares the run down both sides? it just looks like the first one is messed up can it be fixed? the amp still turns on..
Some people should just leave it to the pros *smh*//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifso i was a dumbassss and used the same color for my positive and negative on my fosgate 450s amd smoked poured out so i turned it off quick.. looked and seen i hooked the negative in the postive on the amp and the power into the neg on the amp ****it... here are some pics of the damage.
Wise words...A buddy of mine hooked his Linear Power 5002 up backwards when we were in high school. A little bit of smoke came out of it, but to our amazement, it still worked and nothing was charred on the circuit board. We both learned a very valuable lesson.... You shouldn't try to hook up your amp when you are drunk!
The sad thing is I just sat there and watched him hook his amp up backwards while at the same time laughing my ass off.... Then again, it was his fault for bringing over a case of beer for us to drink while I built his subwoofer enclosure!Wise words...
