Blow through, or drop out the floor?
  • 3
Only The Best
texas
Hey guys! Zach here, I wanted to get some opinions on some design ideas. I made a business when i was 18 building boxes and all kinds of fun fiber/plexiglass enclosures on boats/cars/homes for a couple of years and want to put my experience to back to work now that I am out 1 year out of college. I have a 2013 dodge ram 1500 sport (60,000 miles) and if anyone knows anything about the dodge is that under the backseat is a death pit for headaches with building a box. I plan to do one of two options due to this issue with the truck:
1. I am going to go under the seats and cut out the undercarriage of the truck to drop down a couple extra inches, and weld back a nice square insert to put a much larger box into the truck allowing the space for larger magnets and more airspace.
2. Depending on how much of a pain that will be, I will then decide to just do an average blowthrough. Designs for the blowthrough will be restricted to only the first 2/5 of the bed due to my need of other random stuff. I would also like to build this in such a way that I would be able to remove it should I need to use the entire bed of my truck.
My question is simply, has anyone seen any attempts at dropping out the floor to allow for a large box and high powered system that is firing up under the rear seats. That and how it could compare to doing a blowthrough setup firing forward. Budget for subs/amps/batteries/materials is somewhere between 1500-2500, flexible +1000 (maybe? -options). Thank yall in advance for any input you have to offer.
Is a cap an option? Id do a blow thru by removing the back window and using that as your entry point. Should be good for a couple 15's in a 4th without destroying the vehicle.
Do a blow through it's surprisingly easy and gives you virtually unlimited room. I was pondering different options in my truck like making box that replaces the seats. In the end a blow through was worth it. It gets loud but is also discrete
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
3K
I mixed a trap beat and that christmas song 'silent night' together, then screwed it, bass boosted it, and added a non-stop 25hz note, then put in...
57
5K
been like 20 years since i did just that. 2 l7 15s, 1000watt soundstream usa made amp, 12cu tuned at 34, iirc, that 2 separate vented to the...
5
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Only The Best
Only The Best
texas
DirtyDuzit
Mr FaceCaser
    May 19, 2024
Mr FaceCaser
    May 19, 2024
