Blown CT Sounds 25001.1D
Blown CT Sounds 2500.1D
-2500 watts @ 1 ohm on 12v
-3900 watts @ 1 ohm on 14.4v
Amp was purchased used in April of this year, was not powered until early June. Within 30 mins the amp was smoking. A buddy and I quickly disconnected power and ground cables. Waited until all smoke was gone and amp was cool, reconnected power and ground to amp and nothing. No lights at all. Thought to power on the amp using the bass knob, the amp power on the "CTSounds" logo on top in blue, but actual power light did not come on the side. Also the bass knob says "PROT", which after researching Im taking to mean protect. The amp has a few cosmetic flaws also, such as the gash on the front fin, gash on corner, and loose plexi glass on bottom.
$160 Shippedb (OBO)
Item Pictures: https://lh5.googleusercontent.com/QCY5CTMRPXMmG0vE0VZ7OKEVD1ml304-Bhu3crO2E5De9nFCk9Np5-G5KVLG2lgB-vhqvbJOUAVWJlntTmKAtXWBpO1QYgSZ3vgf=w1040-h750-rw
https://drive.google.com/open?id=0B80pbHUbdJYPbkRIeWxsaHFncEZUd3gwRVJfZWIybVJDRVY4
Is there an issue with your links? I cant open any of them, but my phone's been weird lately.....
Did you take the cover off any look at the board by any chance?
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
989
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
beatzboi
beatzboi
United States
beatzboi
